92' Running Rough - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2005, 04:58 PM   #1 (permalink)
nofear4189's Avatar
View nofear4189's Photo Gallery
Question 92' Running Rough
Ixe owned my 92 pickup 22re 4cyl since august and it hasnt given me any trouble until today. I started it up and drove it over to the side of my house and left it running for maybe 10 + mins while i was in it checking some things inside. I closed the hood, not even toughnig the motor, and got back in to move it back to its spot in the yard. I revved it up a little, maybe 3,000 RPM and backed down the driveway and drove back to its usual place that it sits. IT started running rough (kinda coughing and going under where it is set to idle. I set it to about 1000 RPM and it always did good there before. It jumps around between 500-1000 RPM and acts like it wants to shut off, but it never did yet.I then readjusted the idle a bit, and it seemed to help a little. I let it sit for about an hour this afternoon and went back to it and started up. It started a little rough and dropped back to 1000 immediately. (usually runs about 2000 for 5 mins until warmed up) Then it acted up again, but not quite as bad.
What could be the problem here. like i said, it just started to do it today and will run, but sputters and and coughs a bit. I checked all plug wires, and the obvious, but found nothing. Any help would be appreciated.
-Adam-
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
nofear4189 is offline
Old 02-20-2005, 09:44 PM   #2 (permalink)
View Old Toy's Photo Gallery
Check the fuel filter.
Old Toy is offline
Old 02-20-2005, 09:49 PM   #3 (permalink)
BigBadBlue
View Yoter's Photo Gallery
Carb or EFI? if its carb'd I would assume the float could be messed up. if its EFI I would assume the TPS could be messed up. But in both cases a clean fuel filter is a happy one. LoL, that sounded ghay. Oh well. OldToy is right to change that thang out.
WaState Wheelers check out
WWW.CWOffroaders.ORG
WaState Yota 4x4 owners check out
http://xsorbit28.com/users5/yotacentral/index.php
Yoter is offline
Old 02-21-2005, 02:54 PM   #4 (permalink)
ME
View RICHIE's Photo Gallery
check to be sure all the vacuum lines are attached and none came off.by chance did you change the oil?if you take the lid for the oil fill off and dont put it on all the way it will cause it to run lower than normal.
RICHIE is offline
Old 02-21-2005, 03:45 PM   #5 (permalink)
nofear4189's Avatar
its an EFI. Im gonna try and run it again today and see if the prob persists. Ill check all lines, but i hadnt noticed any off yesterday. Ill check the oil cap too. IF its not better, ill try a filter.
-adam-
