P/u Tape Deck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2005, 11:59 PM   #1 (permalink)
View madtodaimax's Photo Gallery
P/u Tape Deck
I have a 1993 toyota p/u and for some reason, the FM and the cassette deck dont work, only AM does. Any ideas? Also, if i pull another deck from another toyota, such as one I find on ebay or craigslist, how hard would it be to install or would it even be compatible. I just want something that works.
madtodaimax is offline
Old 02-21-2005, 12:34 AM   #2 (permalink)
View ldivinag's Photo Gallery
if it's DIN sized, then it should fit right in, using the OEM brackets. and since toyota has kept the wiring harness plugs the same for all these years, it should plug right in...
leo d.
ldivinag is offline
Old 02-21-2005, 08:50 AM   #3 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
You can get a am/fm/cd player for very cheap. Installation is usually very simple.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 02-21-2005, 10:48 AM   #4 (permalink)
View Uluacam's Photo Gallery
I fit a 2004 Tacoma AM/FM Cassette/CD Player in my 1986 2wd truck.The wire plug in hook-up behind the deck was collected from the local Toyota junkyards.I traced each wire to Power,Speaker,Ground with the use of the Toyota Plug-in Kits for reference, that they sell at Wal-Mart.Original bracket will fit as long it is OEM.
92 Camry V6LE
Uluacam is offline
Old 02-21-2005, 12:09 PM   #5 (permalink)
How much was the Toyota Plug In Kit? Where can i get those?
Old 02-21-2005, 08:26 PM   #6 (permalink)
Its about $15-$20 for the Toyota Universal wire Kit.You can get it at any Car Stereo Outlets.The Toyota original plug-in for Toyota AM/FM units can be found just about any Toyota abandoned at the junkyards.Just got to cut the wires from the vehicle.
92 Camry V6LE
Uluacam is offline
