carb to efi question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2005, 08:29 PM   #1 (permalink)
View fadetoblack72's Photo Gallery
USA carb to efi question
My 94 toyotat is EFI but the used motor i am getting is a 22r. I have been told it's not hard to switch the wotor over to efi by using my 94 intake. Is this true. Can I just swap them and run it?
Thanks,
Jason
fadetoblack72 is offline
Old 02-24-2005, 07:05 PM   #2 (permalink)
This is one busy place
Old 02-25-2005, 12:42 AM   #3 (permalink)
View 87_SR5's Photo Gallery
Thanks,
Jason
I looked around for you and found a link Sidney supplied a while back on Carb to EFI conversion:
http://www.yankeetoys.org/black900rr/EFI.html
I think it would be pretty easy for you since the EFI was already on the truck (no messing with wiring, hoses etc) It would be a little more difficult if you had a carb engine and were installing EFI on it....as it is done in the site above ^^^
Hope this helps
87_SR5 is offline
Old 02-26-2005, 07:33 AM   #4 (permalink)
Thanks for the help. Seems to me it should basically just bolt right up. I'll just have to keep the EFI intake from the old motor (EFI equiped). Thanks for the help
Old 02-26-2005, 12:29 PM   #5 (permalink)
View rcannon440's Photo Gallery
I'm in the same situation. I'm replacing my engine in a 94 pickup EFI with an older carb. engine. I think all you need to do is to switch everthing over, the only question I have is the head the same on a 22RE and a 22R? Do they both have the same Cam? I'm not sure. I was thinking there might be a difference in the camshaft for a carb. engine versus a EFI engine.
rcannon440 is offline
Old 02-26-2005, 04:13 PM   #6 (permalink)
The heads are different depending on the year: http://www.toyotanation.com/forum/t61926.html
Originally Posted by Sidney
Originally Posted by djdinh
Cool thanks,
I'm not actually going to convert from carb to EFI, since it is already EFI. But from what I gathered the heads are compatible, and will just bolt up right?
No they cannot:
81-84 heads=larger chamber and round shaped exhaust ports
85-95 heads=smaller chamber and pear shaped exhaust ports
So as long as your heads are within the same year range, they are compatible.
The camshaft is different between the carb engine and the EFI. At least, that is what I read from the site I listed above ^ http://www.yankeetoys.org/black900rr/EFI.html
Hope this helps
87_SR5 is offline
