1986 gas gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2005, 09:10 PM   #1 (permalink)
View azdave35's Photo Gallery
1986 gas gauge
i just bought a 1986 toyota truck and havent drove it enough to know where on the gauge it runs out.....will these trucks run a few miles after the gauge hits E?
azdave35 is offline
Old 02-23-2005, 10:15 PM   #2 (permalink)
View 87_SR5's Photo Gallery
I guess this depends on if you have a carb or EFI...
I didn't know this, but found out from a previous thread. In a EFI application with the pump in the tank, you shouldn't let the gas get too low. The gas acts as both lubricant and a coolant for the pump. When the fuel level drops, the pump is no longer submerged and will heat up, possibly failing or reducing the life of the pump.....it was just a thought, I had no idea that this could happen, but it makes sense. Here is a link to the thread if you want to take a look.
http://www.toyotanation.com/forum/t65162.html
87_SR5 is offline
Old 02-23-2005, 11:48 PM   #3 (permalink)
mine is carbed
azdave35 is offline
Old 02-26-2005, 02:30 PM   #4 (permalink)
View soadslipknot's Photo Gallery
Gas guage
WHile individual trucks may differ slightly, I can offer you the experience of my four trucks. I had an 85, two 87's, and an 88. All were basic 22r carbed motors. On all four, my guage would go as far below E as it would above F, which was quite a bit. I ran out once in six years, as I was pulling into the station at an 1/8 tank BELOW E.
soadslipknot is offline
Old 02-26-2005, 09:17 PM   #5 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
I have a 86 22re and run tank to tank.....full to empty. Never had a problem with the fuel pump overheating and personally don't believe that is true. Maybe if you actually run it dry but not just from running it low. Guage will go below empty.
My wife hates how I run it to empty. It has become a game now and I have never run out of gas. However, when that day comes.....I will not call her for help, it will be my little secret.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 02-26-2005, 09:26 PM   #6 (permalink)
Fuel pumps
WILL overheat and fail over time...this is coming from personal experiences.
Old 02-27-2005, 08:14 AM   #7 (permalink)
texas12's Avatar
Yes it will fail over time. So will your engine under normal use. Anything mechanical WILL fail over time. I am just saying there is no need for external lubrication of a fuel pump, IMO.
texas12 is offline
Old 02-27-2005, 11:33 AM   #8 (permalink)
View westontop's Photo Gallery
I've got a '86 xtra cab with 22r and carburator. My gauge goes well below empty and when extremely empty the red idiot light 'fuel' comes on. I've never run out of gas. My gauge does act weird however hen starting the truck. It always tells me there is more gas when I start and warm up than after it is warm or even running about 3-5 minutes. I don't know if the gauge is faulty, becuase it does this regularly, as if it's trying to tell me on start up how much fuel plus reserve there is, and then just reports the fuel minus reserve.
westontop is offline
Old 02-27-2005, 07:16 PM   #9 (permalink)
badazztoyz
mach9's Avatar
View mach9's Photo Gallery
gas gauge
on my 88efi when the gas light comes on soild, it will flicker for a while, u have 10-12 miles
mach9 is offline
