22re oil pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2005, 05:19 PM   #1 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
22re oil pressure
Does anyone know the resistance that an oil pressure sender should have at idle and at 3000rpm?
I just did a cluster swap (changed the switch to a sender) and cannot get the oil pressure to read. If I short the wire the guage will read high (full deflection). I get no deflection with the sender hooked up.
Read resistance at cluster:
Engine off = open
Engine idle = 120 ohms
Engine 3000rpm = 80 ohms
Manual shows 4.3 psi (min) at idle and 36-71 psi at 3000rpm. I don't have a guage handy to check actual psi pressure, so was wondering if anyone knew or could check what resistance the sender should read.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 02-27-2005, 02:25 PM   #2 (permalink)
texas12's Avatar
Hooked up a pressure guage today. 37 psi at idle and a little over 60 at rev. Looks like my cluster guage is bad. That might explain the good deal I got off ebay.
texas12 is offline
