re-setting check engin light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2005, 01:44 PM   #1 (permalink)
View indiana5881's Photo Gallery
well i did the Seafoam in the manifold thing through the brakeboost vacume line and now my check engin light is on all the time. is there a easy way to reset this or do i need to bring it to a dealer? everything seems to be running fine after the treatment.
indiana5881 is offline
Old 02-27-2005, 01:47 PM   #2 (permalink)
View virtualkuz's Photo Gallery
take it to autozone. They can tell you what the code is and clear it for you for free. My guess is that you broke up some carbon and fouled up a sparkplug and you are getting a misfire now. If they tell you it is a misfire code then you have to replace your plugs, hope you have a 4 cylinder and not the V6 if you want that to be easy
2005 Corolla XRS Silver Streak Mica
2005 Kawasaki Z750S Candy Plasma Blue
1993 Kawasaki EX500a Luminous Polaris Blue
virtualkuz is offline
Old 02-27-2005, 08:28 PM   #3 (permalink)
View crazycruzer's Photo Gallery
Usually if you disconnect the battery for about 5 minutes it should reset. If it does reset and comes back on, then you need to check the code.
crazycruzer is offline
Old 02-27-2005, 08:35 PM   #4 (permalink)
View dexter_5000's Photo Gallery
you can usally pull the efi fuse if you don't wanna loose your radio stations.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline
Old 02-28-2005, 12:13 AM   #5 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $903564
View humanoid's Photo Gallery
Yeah, the EFI fuse will work. It's the big square black looking one and not the little 15 amp one.
This is my sig.
humanoid is offline
