350 swap fuel question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2005, 06:01 AM   #1 (permalink)
View wolfie104's Photo Gallery
i have a 1994 toyota 4x4 that i put a carbed chevy 350 in. we got it fired up yesterday, but i have a question about fuel delivery. when i have the stock fuel pump connected, it puts out way tooo much fuel, and when i pull the fuse for it, it seems like its not getting enough with the mechanical pump (maybe the stock pump is restricting it ). can i leave the stock fuel pump hooked up and run a regulator? if so, what is a good regulator to use? the 350 is carbed and the toyota was 22re efi. if the stock toyota efi fuel pump is pushing around 40psi, why cant i just add a fuel regulator that regulates the fuel down to 5-9 psi on the fuel line? will this work ? what do i need to do with the mechanical chevy pump? please tell me how to do this! any help is greatly appriciated!!!
wolfie104 is offline
Old 02-28-2005, 09:05 PM   #2 (permalink)
View Gene J's Photo Gallery
The EFI pump puts out like 35-45 PSI and a non EFI pump puts out maybe 5-7.
By pulling the fuse the pump is now a restriction.
Is it an intank pump or external? If external you can either replace it with a pump from a speed shop or just replace it with a hose and let the engine fuel pump do all of the work.
Gene J is offline
Old 02-28-2005, 09:10 PM   #3 (permalink)
View crazycruzer's Photo Gallery
You can get a fuel pressur regulator from Jeg's or Summit. As for the mechanical pump, remove it, sell it on Ebay, and get a fuel pump block off plate from Jeg's.
crazycruzer is offline
Old 03-01-2005, 06:35 PM   #4 (permalink)
View 00Yoda's Photo Gallery
What he said, friend did this exactly on his 302 in a ranger, works like a charm
00Yoda is offline
Old 03-02-2005, 08:40 AM   #5 (permalink)
Pre Taco= Built Better
View toyota_s_runner's Photo Gallery
Mine runs 9lbs on a mechanical pump. It also has a relocated fuel pickup tube( see in the picture).The fule line is 1/2 in size and uses nothing that was part of the stock Toyota and I don't have any problems. If you go with the stock pump in the tank make sure you have a return line for the pressure you bleed off.
www.tacomasrunner.com .......
toyota_s_runner is offline
