need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2005, 08:41 PM   #1 (permalink)
View jasonhow's Photo Gallery
Angry need help
imy roommate has a 91 toy truck sr5 v 6 and his clutch is not working he said it worked fine then he parked it came back out and bam no clutch is there something that may have poped or does he need a new clutch help is appreciated
"Stoned Is The Way Of The Walk"
jasonhow is offline
Old 03-01-2005, 09:15 PM   #2 (permalink)
View toyocsd01's Photo Gallery
Does the clutch drop to the floor with no resistance? Did you check the fluid reservoir under the hood?
toyocsd01 is offline
Old 03-01-2005, 10:17 PM   #3 (permalink)
yup checked it all maybe slave?
jasonhow is offline
Old 03-01-2005, 10:49 PM   #4 (permalink)
ok heres the deal... we thought that maybe it was the master cylender b cause we saw that the metal hose that goes to the slave and it was lose so we went and got some brake fluid and bled the line... now we have no air in the line.... so we started it.... and nothing.... the pedal has nothing and is goey so now is it the master that needs to be replaced???? the clutch???? or the slave???? i am limited on cash and cannot do all three at this time so any info would help
thx for the help
jasonhow is offline
Old 03-03-2005, 01:26 PM   #5 (permalink)
View ToyoLoyal's Photo Gallery
Still sounds like a hydralic problem. Have you tried pumping the pedal and see if it gets better. Have someone watch the slave cylinder and clutch fork while someone else pumps the pedal. Does the clutch fork move? How much?
ToyoLoyal is offline
Old 03-04-2005, 03:31 PM   #6 (permalink)
ok we figured it out it was the master cylinder...but.... the aluminum plate where the master comes in was torn and we had to drill trough to bolt this down and make it so it wasnt jacking the master side ways a bunch of shit.....so 2 days and 4 knuckles later... up and running
jasonhow is offline
