Do you have the stock intake tube? If so, I don't think you could have sucked that much water unless it was actually submerged in water. I think you need to look more into the basics before you go condemning your engine.
Pull your plugs, leave the key OFF, and run a wire from battery '+' to the starter solenoid. The engine should turn over if the battery is good.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
