changing head gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2005, 08:39 PM   #1 (permalink)
View mav7593's Photo Gallery
New member here and also my first Toyota truck. Bought a 88 4wd with 120,000 miles about a week ago and I need to change my head gasket and I was wondering it there were any other gaskets that need to be replaced when doing this. I plan on changing my head bolts but I wasent sure what else might be affected when pulling the head.
Thanks in advance
Jason
mav7593 is offline
Old 03-04-2005, 09:01 PM   #2 (permalink)
itz a what thing?
View burger's Photo Gallery
Thumbs up
If it is a 22re,you will want to change the intake gaskets on the "split " intake,removing this makes removing the head much easier,just take your time with the wiring harness'cause it's a P.I.T.A.-you might want to throw on a new exaust gasket as well,it depends on the condition 'cause they can be reused and are expensive to boot. good luck!
burger is offline
Old 03-05-2005, 02:18 AM   #3 (permalink)
About how long should it take to do the head gasket, any ideas? I am a little irked that I have to do this after just buying the truck but I hope it will turn out to be a good truck.
mav7593 is offline
Old 03-05-2005, 07:02 AM   #4 (permalink)
View Sidney's Photo Gallery
I would also see if it's time to replace the timing chain components.For what gaskets you need to replace as well read the links below this article.
Most engine wear on any engine occurs at startup with that said the R series Toyota engines such as the 18R,20R and 22R all use a timing chain which it's tension is supplied by hydraulically driven timing chain tensioner which has it's oil pressure build up few seconds after the engine has started therefore the timing chain rubs on the driver's side brown colored nylon/plastic timing chain dampener or guide and after so many miles (140-170 000 miles in the city with the average 4 starts per day) the driver's side guide breaks through causing the chain to rub on the timing chain cover for the first few seconds upon startup and when driving in 5th gear and letting off the gas.
Usually by this point the other timing components such as the camshaft sprocket,crankshaft sprocket and chain have their specs out of tolerance and hence must be replaced as well.The tensioner sometimes sticks due to dirt build up and other problems arise as well and must be replaced as well,all of those parts are sold in the aftermarket world as a "timing chain kit" which also include gaskets and a front oil crankshaft seal.Toyota on the other hand for some reason does not sell the parts as a kit but as individual parts which would cost around $400+ and from all of the reading I have done on many Toyota 4-Runner/pickup discussion sites I have come to the conclusion that many experienced off-roaders who cannot afford to buy all of the genuine Toyota timing parts instead buy the chain and tensioner from Toyota and the other parts from aftermarket as a kit but of course don't use the aftermarket chain or tensioner.
The best brand of aftermarket timing chain parts to use on the 20R & 22R series Toyota motors are:
http://www.engnbldr.com/ToyotaHotlicks.htm
http://www.22r.biz/
http://www.rpmrons.com/toyotatiming.html
http://www.npr-america.com/index.htm
http://www.autotoyotaparts.com/toyota-truck-parts.html
http://www.toyota-engine-parts.com/
http://www.europeanautomotive.com
and if you choose to buy from Toyota these places have the best prices in the USA & probably the whole world:
http://www.1sttoyotaparts.com/partscat.html (10% shipping)
http://www.toyotadiscountparts.com (free shipping with $100 & up)
http://www.Toyotaparts4U.com
http://www.toyotaofplano.com
Other ways to check timing chain wear are:
http://www.misterfixit.com/chanslop.htm
you can also remove the valve cover and take a flashlight and see if the driver's side timing chain dampener or guide wore through.
You can bend 1 to all 8 valves and have timing cover eaten through if you wait and then coolant and oil mix together to give you butterflies in you stomach.You can do a fluid analysis on your engine oil by going to any Caterpillar and buying a fluid analysis kit for around $15-20 and taking a sample of your old oil.
Finally these sites explain the timing chain replacement well:
http://yotarepair.com/22R%20timingchain.html
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
http://www.4x4wire.com/toyota/maintenance/timingchain/
Sidney
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 243 000 KM
Sidney is offline
