Head bolt Problem, HELP??
Well, I finally broke down and bought a new Header, Steel Timing Kit, and new Engine builder Cam for my '89 Extended Cab Pickup's 22RE engine. I waited all week to install this and on Saturday morning was up bright and early. Header went on great, no problems here. Started tearing engine apart, everything went great until I got to the head/rocker assembly bolt second from rear on drivers side. It would not budge. A 12 point socket was starting to round off the bolt head so I switched to a Craftsman hex head instead. My breaker bar was not moving this thing. I found a cheater pipe and noticed the bolt head flexing a little but not coming loose. I then fired up the compressor and broke out the 1/2" impact. Nothing moved, just a lot of noise. By now I figure I will probably break off the bolt and have decided I can live with that and rebuild the whole engine after a trip to the EDM shop. I find a longer cheater pipe and go to town. BAM!! A few busted knuckles and my socket is broken in 4 pieces, but the damned bolt is still there. I give up! I started putting it back together and then quit. Anybody have any miracle cures for this problem? I am very disappointed and really do not want to put it back together without installing this cam which was my main purpose of this whole project. Any help is appreciated.
Thanks,
Dan
