Wiring on a 1993 Toyota p/u - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2005, 06:27 PM   #1 (permalink)
View madtodaimax's Photo Gallery
I have a 1993 toyota p/u with the 22re motor. I bought an aftermarket horn and foglights. Does anyone know where i could run wires to the dash to moun the switches. Do i need to drill a hole, where if i have to, or is there a hole i havent found. Also, any ideas on on switches
madtodaimax is offline
Old 03-07-2005, 03:19 PM   #2 (permalink)
View tdr racing's Photo Gallery
Hey try this link out hope it helps you out.http://www.autozone.com/servlet/UiBr...n=viewHomePage
tdr racing is offline
Old 03-07-2005, 06:29 PM   #3 (permalink)
comes out to the autozone home page? can u tell me where u found it?
Old 03-07-2005, 06:59 PM   #4 (permalink)
Try looking at Chassis Electrical.
Old 03-07-2005, 07:17 PM   #5 (permalink)
JerryRigger
View woundedfate's Photo Gallery
I wired up some offroad lights in my '89 and I put the switch in the dash right above the e-brake. I got every thing i needed at radio shack but I did have to cut out my own hole with a knife.
woundedfate is offline
Old 03-07-2005, 08:30 PM   #6 (permalink)
where did u route the wires?
Old 03-08-2005, 08:04 PM   #7 (permalink)
nofear4189's Avatar
View nofear4189's Photo Gallery
mine are routed from the dash, over to the inner fender well, and out into the eng compartment, then i ran them down the front and across. my truck was already wired from a previous owner's lights, so i just had to redo the ends and route the ends of the wires a little differently. My power source is the cig. lighter. Since the lighter is right under the cutout for the switch, i guess he found that spot most convenient.
-Adam-
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
nofear4189 is offline
Old 03-09-2005, 12:54 AM   #8 (permalink)
how did u get it through the inner fender well and did u just go through the door jamb. I think i saw the gap you are talkin about but couldnt figure out where it ends up and if it was safe to pass the wires in the jamb
Old 03-09-2005, 04:14 PM   #9 (permalink)
nofear4189's Avatar
it goes from behing the glove box, through the firewall, and down between what i call the "inner" and "outer" fender wells. Its kinda hard to explain. I didnt do that part of the wiring, so im not 100% sure how they got the wires down there. If i were you, id jsut run them through the firewall and run them inside the engine compartment away from heat and potential places where water could lay, and then down to the front of the truck.Just make sure your connections are always wire-taped tightly just for insurance of a waterproof connection.
-Adam-
