Did you check the actual battery? Sometimes batteries will die just like that. If battery still has good voltage, check the fuses in the box next to the battery. There are a couple of big ones in there that do NOT pull out, so don't try. If one of those are bad, they unscrew from the bottom. There are other fuse in there that can be pulled and checked, but check your battery first. Also make sure you have a good ground to the battery.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
