Thanks qsd-dan, I will check witht the dealer and a few other sources if there is a difference in non-a/c and and a/c models. I am also wondering if the shop I had the unit installed can add a fan for the a/c condensor on the front of it, and maybe see if it either can turn on when the other fan turns on or at least when the a/c is turned on.
I did a little test on my truck yesterday, had it sitting in the driveway for about 25-30 mins running first with out the a/c unit on for about 10-15 mins, and then with the a/c unit on for about 10-15 mins. I did this with the hood closed just to see if it would overheat just running while parked and it never got over the half way point. I was pretty glad about this but I also understand the engine was being reved up, like in normal driving, so I assume the engine would not get as hot.
"Talk does not cook rice"
-Old Chinese Proverb
