22re timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2005, 05:01 PM   #1 (permalink)
View 94yo4X4's Photo Gallery
22re timing
any tips on timing a 22re cause it seems that everytime i try i cant get the timing in the timing degree and what is the most advanced or retarted that the engine will start
94yo4X4 is offline
Old 03-09-2005, 12:22 AM   #2 (permalink)
View tdr racing's Photo Gallery
set the crack pulley at zero or should i say top dead center. and make sure the number one piston is up then set distributer at one then jumper the diagonostic its a little grey box next to the fuse box. the jumper code are TE1 to E1 you can us a paper clip to jump it then turn on the key with jumper on then let it set for about five minutes or so. then start it with jumper on and shoot the timing and adjust it to proper specs.it should be at 5 botc when in jumper mode. thas at normal idle speed. hope this helps you out.
tdr racing is offline
Old 03-09-2005, 04:58 AM   #3 (permalink)
View fadetoblack72's Photo Gallery
Botc?????
fadetoblack72 is offline
Old 03-10-2005, 11:16 AM   #4 (permalink)
I meant to say 5 BTDC.
Old 03-11-2005, 04:58 AM   #5 (permalink)
Oh ok. I got confused. Don't worry about it though. Not hard to do. Lol.
