Nice write-up
The only thing i would add is a big washer between the rod ends and the hitch pin.
If you don;t have the skills to do this, there is only one way to get them
This makes a good starter project for someone that will be doing enough off roading that they will need a quick disconnect.
You may want to give it a shot. Worst case scenario, you put it back to stock and learn alittle about your trucks suspention.
Next thing you know you'll be fabbing a rear bumper with hitch D-rings and a tire carrier
