emission problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2005, 03:37 PM   #1 (permalink)
View tdr racing's Photo Gallery
emission problems
I have a 1994 toyoa p/u 2wd reg cab efi.I just failed emission test and the carbon monoxide is high and also hydrocarbons, I was wondering does anyone have an idea on what may cause it to be so high.
tdr racing is offline
Old 03-10-2005, 12:30 AM   #2 (permalink)
Trailer Trash Engineer
alltrac165's Avatar
View alltrac165's Photo Gallery
AFM, TB, or O2 sensor would be my guesses
When's the last time you gave it a good tune up, plugs, cap, rotor, set the timing, etc.?
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
alltrac165 is offline
Old 03-10-2005, 06:15 AM   #3 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Im guessing converter. Of course anything is a guess without actually checking it out. May be multiple problems.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline
Old 03-10-2005, 11:02 AM   #4 (permalink)
its a rebuilt motor with a new head and it has new plugs,air filter,rotor, cap,wires. just put the motor in like three weeks ago,timing is good.the only thing i did not is the o2 sensor is there a way i can test the o2 sensor ?
Old 03-10-2005, 07:25 PM   #5 (permalink)
ShawnM's Avatar
What was wrong with the old motor? Oil blow by will kill a converter and coolant in the combustion chamber will kill an O2 sensor. Keep in mind if its a recently rebuilt motor it will burn some oil untill the rings wear in a little.
--Shawn
03 Camry LE
67 Mustang
ShawnM is offline
Old 03-22-2005, 04:38 AM   #6 (permalink)
View nmoen's Photo Gallery
What was your O2 and CO2 readings. List all of the gas values listed on your vehicle inspection report. With those readings, I can steer you in the right direction for successful repair. Shawn does have a good point - What was wrong with your last motor? Oil, coolant, excess Hydrocarbons from engine misire can all cause CAT failure.
Neal
nmoen is offline
Old 03-22-2005, 10:07 AM   #7 (permalink)
View crazycruzer's Photo Gallery
If your results show that you barely failed, then all you have to do is put in high octane fuel and add in some octane booster and you should pass (unless you can find a station that sells 100 octane fuel).
crazycruzer is offline
Old 03-22-2005, 11:18 PM   #8 (permalink)
Octane booster will help NOx emissions only. Keep in mind, octane simply stated is resistance to burn. If you slow down your burn, you will increase your hydrocarbons. Does arizona test for NOx? What's your O2 and Co2 readings? I am a CA smog tech...I can help you but I need to know all the readings.
Neal
nmoen is offline
Old 03-24-2005, 07:22 PM   #9 (permalink)
Here are the results in case you didn't get it in your own email. hydrocarbons (HC) is 2.16 applicable standard is 1.60, for carbon monoxide (CO) is 101.72 and the applicable standard is 20.00, and for oxides of nitrogen (NOX) is 0.09 and the applicable standard is 3.00 and as you can see I failed HC and CO and also just to let you know I passed the gas cap test and the pressure test. As for the other motor you guys were asking what was wrong with it it had a major valve leak and every morning when I start it it would throw out smoke and like I said everything is new the only thing I did not change is the O2 sensors and fuel injectors, but it has a new catalytic converter so the only thing I can think about is the O2 sensor. i appreciate your help. thanks.
Old 04-03-2005, 08:59 PM   #10 (permalink)
View Tamme's Photo Gallery
Hi everyone,
I have the same problem on my sedan Camry 91. It just fail the emisson test:
. . . . . . . . .Reading . . . . . . Limit
HC . . . . . . 02.10 . . . . . . . 01.20
CO . . . . . . 60.60 . . . . . . . 20.00
NOx . . . . . 00.11 . . . . . . . 02.50
Would you please give me some clues. Thank you very much!
Tamme is offline
Old 04-04-2005, 10:03 AM   #11 (permalink)
Banned
turbos17's Avatar
View turbos17's Photo Gallery
Try to retard (lower the timing) the engine a bit. The guy doing your smog test should be able to do it, if he is cool and wants to get his money. If not you are SOL! Good luck!!!
turbos17 is offline
Old 04-04-2005, 10:56 AM   #12 (permalink)
Hi turbos,
Do you mean that I have to delay time point of combustion a little?
Tamme is offline
Old 04-05-2005, 10:08 AM   #13 (permalink)
Hi tdr racing,
Do you know what is wrong on your car yet ? If yes, could you let me know ? My car was also fail CO and HC. Thank you very much.
Tamme is offline
Old 04-08-2005, 01:52 AM   #14 (permalink)
Hi Tamme, I have not yet found the problem I'm waiting for a reply from (nmeon)he is a smog tech and he said he needed my emission readings to help me out so as soon as I find out I'll let you know and try to help you out .
Old 04-18-2005, 07:05 AM   #15 (permalink)
Hi tdr,
I believe that my car problem due to MAF system. In my car, the MAF has an adjustment screw. But I do'nt know how to adjust it. If somebody know how to adjust it (procedure & specification) please let me know. Thank everyone.
Tamme is offline
