22re wont start after repairs
ive just finished rebuilding some of my 22re motor in my 1994 pickup 4x4. The cylinder head was sent out to a machine shop where i had a valve job and a compression test done, it passed. i replaced the timing chain/guides/tensioner, thermostat, spark plug wires, plugs, water pump, and all gaskets. from what ive seen its hard to screw up the valve timing considering there are very obvious mark on the cam and crank gear pluss the bright links on the chain and the cam gear only goes on one way. I followed the procedure for setting the timing (tdc then distrubtor at #1)
but the engine wont start ive got one cylinder to fire but it also backfires while trying to start every 4-5 sec that the starter is spinning. ive tried the jumper thing in the diagnostic box too. i cant figure out what it would be now my only guess is that the wiring may be messed up. i do have to wires that are hanging down that arent plugs they just have normal ends like you would see on a car sterio speaker cable. i do not have the mass air flow sensor on or the air box yet i was gonna wait till i got it started. i also what looks like two sensor outlets on the right side (intake manifold side) of the block that i cant find any thing to plug into them. i cant afford to take it to a mechanic so i would really apprecaite the help......thanks
