I know that on a 22RE motor, the ESA system will adjust the timing on the fly, so it's normal for the timing mark to move around a bit. However, during smog tests, I believe they usually short the T-E1 connector, at which time I think the timing should stay right at 8deg BTDC. I'm not familiar with the V6 motors, but they may operate on the same kind of system.
If the timing is indeed jumping around abnormally, your distributor could have some slop in it.
As for your smog results, was your catylitic converter nice and hot before the test? They won't clean the exhaust gases very well until they've been heated up. My truck wouldn't pass my last smog test, and I ended up having to put a new cat on it. Oddly enough, my truck wouldn't pass at the 15mph test, but would pass at the 25mph test.
John G
