turbo anyone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2005, 12:13 PM   #1 (permalink)
View 94yo4X4's Photo Gallery
turbo anyone?
ive got a 94 pu with a 22re and ive seen lots of products for turbo charging. im in serious need of more hp and an intake and exhaust arent gonna do it for me.. how hard is it to install a turbo on the 22re? ive read a lot about the kits and parts i just want to hear from some one that has experienced it or has tried to do it.....thanks
94yo4X4 is offline
Old 03-14-2005, 03:25 PM   #2 (permalink)
View bvenvert's Photo Gallery
I don't have any experience with installing a turbo on a Toyota Pickup, but I have a 1986 Toyota Turbo 4X$ Pickup. I don't know if you would really get a bang for your buck on a turbo'd 4 cylinder. Although I am sure that my 4 cylinder turbo winds up quicker than a stock 22re, I really don't think you are putting a bunch more HP to the ground. You might want to look at some other options, like a six cylinder model if you need more horses.
bvenvert is offline
Old 03-15-2005, 05:49 PM   #3 (permalink)
View dgr00s's Photo Gallery
check out lcengineering.com
dgr00s is offline
Old 03-15-2005, 05:54 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
It's far cheaper and better results to swap in a GM 4.3v6.
雄のハヤブサ
Tercel GTS is offline
Old 03-17-2005, 07:55 PM   #5 (permalink)
View Flash319's Photo Gallery
You will run into some problems when putting a turbo on a no-turbo 22RE. The compession is to high and the computer will not understand a pressure in the intake instead of a vacuum. There are ways around that but I think you will be into more of a headache then it is worth. Get a bigger engine if you want more power. Stay with the 22RE if you want a bullet proof engine!
Flash319 is offline
Old 03-17-2005, 08:36 PM   #6 (permalink)
View corollasr5's Photo Gallery
run the truck, buy a turbo car, that ends your dilemna
corollasr5 is offline
Old 03-17-2005, 09:07 PM   #7 (permalink)
N/A bites
Tercel GTS's Avatar
I'd hardly call the 22r bulletproof.....
Throw a lil more compression on it and it'll stretch them long head bolts in a short time. And then there's the timing chain/water housing issue...
I'll say I never chucked a rod, but it wouldn't turn more than 7,500 rpm in any gear.
雄のハヤブサ
