How do I remove my radio? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2005, 12:43 PM   #1 (permalink)
J Dubb
TRDTURD's Avatar
View TRDTURD's Photo Gallery
This 03 Tacoma I have is my first yota and I've never removed the radio in one. Can someone tell me how it comes out. It looks like the heating control panel overlaps the dash piece around the radio as well as the air bag cut off switch. I was afraid to start pulling and tugging. Thanks for any advise you can give.
2010 Tundra Double Cab - TRD 4.6L
2009 Camry - SE V6
TRDTURD is offline
Old 03-19-2005, 07:48 PM   #2 (permalink)
View BoilerBronco's Photo Gallery
Hey TRDTURD,
I'm going out on a limb here because I do not own a Toyota at the present time, but I do have tons of audio experience.
I'm assuming that your radio is a typical "DIN" style radio. If so, then you'll notice four small holes, two on each side, at the very outside edges of your radio. You can use number 8 naills to insert through the holes to "unlock" your radio. Then you can slide it right out.
BoilerBronco is offline
Old 03-19-2005, 09:44 PM   #3 (permalink)
View fadetoblack72's Photo Gallery
I own a 00 tacoma and I just had to take the lower dash apart. piece by piece. the the radio has 4 bolts.
fadetoblack72 is offline
Old 03-19-2005, 09:58 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Yeah, most toyota factory din radios have 4 bolts.
雄のハヤブサ
Tercel GTS is offline
Old 03-20-2005, 12:09 AM   #5 (permalink)
taco roller
View JETACO's Photo Gallery
i was wonderiing the same thing, i want to put a different head unit in my 01 taco. i just installed a rockford fosgate power hx2 sub in my taco and for the amp i had to use an rca converter, are you planning on putting in a dvd player or something, bc i would like to know how it would be like in a taco
2001 taco, red with silver trim, chrome nerf bars, bull bar, and pipes. v6 sr5 TRD 4x4, rockford fosgate power hx2, hid 6000k
JETACO is offline
Old 03-20-2005, 12:44 PM   #6 (permalink)
J Dubb
TRDTURD's Avatar
Thanks, I did not see any holes in the face of the radio. I know what your talking about though, it's that way for Fords. I think I'll have to start at the bottom of the dash like fadetoblack said and see how that works.
2009 Camry - SE V6
TRDTURD is offline
Old 03-23-2005, 05:04 PM   #7 (permalink)
J Dubb
TRDTURD's Avatar
I got the radio out. Start at the bottom and remove the plastic that holds the auxillary outlets. Remove two screws holding the ashtray frame in. Remove one screw behind ashtray. Remove air control knobs and snap off air control panel. Remove two more screws behind air control panel. Pull the plastic panel off. Thats its basically, I might have left out a screw but you'll know if you did.
2009 Camry - SE V6
TRDTURD is offline
