Cold air intake? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2005, 04:57 PM   #1 (permalink)
View coffee33's Photo Gallery
Question Cold air intake?
Hello all!
I have a 1993 2wd Toyota Pickup with the 22-re 4-cylinder engine on it and I would like to know alittle about cold air intakes. I see cheap ones on ebay and expensive ones made by K&N. They claim performance gains up to 26HP. Up to...that probably means 3hp gains.
I want to get one for my truck but I'm not shelling out 200$ on something that might get me 5HP.
Any suggestions from some that uses cold air intakes?
Ty and have a good day!
Coffee
coffee33 is offline
Old 03-21-2005, 06:53 PM   #2 (permalink)
View greasyjeep's Photo Gallery
you can make your own?
some PVC, a cone filter and a ruber adapter and you will be good to go.
Spray paint helps too.
Otherwise I would tell you not to waste your money, not the most popular opinion on here, I just don't think CAIs are worth it unless you hook it up to some type of snorkle so you can go through deep water when wheelin.
greasyjeep is offline
Old 03-21-2005, 09:54 PM   #3 (permalink)
My god you sould like my dad lol...ok, I'm going to actally try it since your the 3rd person that has said this hehe.
Ty for your time
coffee33 is offline
Old 03-22-2005, 12:04 AM   #4 (permalink)
View madtodaimax's Photo Gallery
how hard is it to swtich the battery and the intake? if im going to make my own pvc pipe cold air intake, id probabyl benefit more from switching the two, getting rid of the 90 degree angle before the efi body.
madtodaimax is offline
Old 03-22-2005, 06:15 AM   #5 (permalink)
You can kinda see mine here, the snorkel is in the top picture on the passenger side (the little hard hat looking thing) and the intake it he piece of PVC the the stock air intake (black tube is attached to (that is the best pic i have of it under the hood, but you get the idea. the big silver bullet attached to the intake is just part of my OBA.
the hardest part was figureing out what size pvc would fit and what filter to use.
I didn't use a K&N i used an other companies, cna't remember now who's but i also used a pre filter cut out of a big fram box filter to keep out dust.
good luck.
Old 03-22-2005, 09:48 PM   #6 (permalink)
BBB's Lil friend!
View K'sToy's Photo Gallery
The k&n FIPK will get you around 12hp give or take.
Heres a link with some cool stuff to increase you performance on the 22re
http://www.yotatech.com/~corey/tech/...ark_engine.htm
BBB's Lil friend.
1989 Toyota Xtra cab SR5 pickup with sunroof and 31x10.50" Wildcat tires. The process has begun!
http://roots.zapto.org/~cwo/index.php Central Washington Offroaders! Join Today!
K'sToy is offline
Old 03-23-2005, 12:03 AM   #7 (permalink)
tcr22's Avatar
View tcr22's Photo Gallery
i have one of those home intakes on my 93 22re. you will get maybe 8 hp gain.
but you do the mass air flow sen trick to and if you put headers on will get a better hp gain
tcr22 is offline
Old 03-23-2005, 01:16 AM   #8 (permalink)
View 87_SR5's Photo Gallery
I am just curious....MAF sensor trick????
87_SR5 is offline
Old 03-23-2005, 08:32 AM   #9 (permalink)
Young Buck
ElmerFudd's Avatar
View ElmerFudd's Photo Gallery
does anyone know price ranges on headers and a cam for the 22RE? I have to do my valve seals anyways.. so i thought it would be a good time to look into a more agressive cam for a bit of HP gain.
90' Toyota HTP Pickup 22RE 3" Body Lift Breathin K&N with 31" Sneakers.
ElmerFudd is offline
Old 03-23-2005, 11:31 AM   #10 (permalink)
View black93DX's Photo Gallery
headers 250-500 depending on company and finish. Cam 300-600.
93 DX Ext. Cab.- 5 speed,FM40,K&N,31x11.50 RVT's
black93DX is offline
Old 03-23-2005, 03:59 PM   #11 (permalink)
Toyota Fanboy
Bakemono's Avatar
View Bakemono's Photo Gallery
You can get headers through a company called Performance Products.
Ceramic coated headers cost you $378.95 and steel headers will cost you anywhere from $207.95 to $393.95.
Cap'n
Originally Posted by Vmax2007 View Post
Toyota is not any more "special" than every other company the media has targeted in the past.
'07 Toyota Camry LE
Toyota: Like other cars, only better.
Bakemono is offline
Old 03-23-2005, 04:56 PM   #12 (permalink)
J Dubb
TRDTURD's Avatar
View TRDTURD's Photo Gallery
Go to gadgetonline.com and read what they say about K&N before buying. That link was provided by another TN member and it changed my mind. Glad I did not waste my money.
2010 Tundra Double Cab - TRD 4.6L
2009 Camry - SE V6
TRDTURD is offline
Old 03-23-2005, 05:56 PM   #13 (permalink)
tcr22's Avatar
yes, the trick were you can adjust your MAF to make it lean or rich
tcr22 is offline
Old 03-23-2005, 07:18 PM   #14 (permalink)
Official Saipan Member
rogerman's Avatar
View rogerman's Photo Gallery
Ive seen one of the best engine upgrades so is from LC Engineering but u gotta shell out quite alot its like a grand but u get everything Headers, Cam, Exhaust ect all the stuff u want all at the same time or u could just order it seperate now about the snorkle they dont make any for 22re's but they do for v6 and u could just wing it and use pvc or a ricer intake kit
1992 Hilux 4X4 22R-E Manual, LCE Headers, Epn cam, super 40, and revirginized.
rogerman is offline
Old 03-23-2005, 08:15 PM   #15 (permalink)
BBB's Lil friend!
LC engineering has lots of products.
www.toyotacatalog.net
BBB's Lil friend.
K'sToy is offline
