head gasket 85 4-runner 22re - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2005, 07:58 PM   #1 (permalink)
View magoo_16_99's Photo Gallery
does anyone know if it is possible to install a head gasket without removing the intake? Was wondering if i could get the head high enough to slide a new gasket in
magoo_16_99 is offline
Old 03-22-2005, 12:23 AM   #2 (permalink)
View ttownjoeshow's Photo Gallery
Yep its posable, but alot more frustrating work i'd say....gotta be able to clean the mating sufaces for the gasket
3 '86 Toy P/U 4X4... 22R-TE auto stock, 22R-E manual 4" susp 3" body &35's 5:29gears, and a 22RE 4Runner, daily driver.
ttownjoeshow is offline
Old 03-22-2005, 10:23 AM   #3 (permalink)
View crazycruzer's Photo Gallery
Everytime you change the head gasket you should have a machine shop look at the heads to make sure they're not warped. If you change the gasket and have a warped head, then you're just wasting your time and money.
crazycruzer is offline
Old 03-22-2005, 07:28 PM   #4 (permalink)
itz a what thing?
View burger's Photo Gallery
you can remove the head without removing the intake,it is a pain because you do need to get the head out of the engine bay to clean it up proper,which means disconnecting the wiring harness which goes right back to theO2 sensor.You can check the head by rolling a metal pipe across the deck surface lengthwise .not perfection,but it'll do.
burger is offline
