How to remove Inner Cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2005, 08:02 AM   #1 (permalink)
View Bugdude's Photo Gallery
Question How to remove Inner Cover
I have a '93 Toyota P/U and I need to remove the inner cover on the doors that are on the front end of the window, some mirrors attach there. mine does not have the mirrors attached there, they are mounted to the door itself. this cover is the shape of a boat sail, or a D. I want to remove it with out breaking it. can someone Help?
you can see it here
http://personal.utulsa.edu/~nathan-...l/3frontdoo.pdf
just scroll down a little and you will see it.
Bugdude is offline
Old 03-22-2005, 09:18 AM   #2 (permalink)
View Forstr's Photo Gallery
There's a sort of a clip attached to the cover itself at the bottom, or the base (if you think about it as a triangle). When installing it, the bottom goes in first. There is also a ring of foam/weatherstrip attached to the inside of the cover. Whether or not that is advhesive to the door, I'm not sure.
I would gently and slowly pry it out from the top. You may have to work a puttyknife in there to separate the foam from the door, if in fact it is adhesive.
Forstr is offline
Old 03-22-2005, 02:56 PM   #3 (permalink)
forstr
Thanks I will give that a try.
Bugdude is offline
