Body Lift or Suspension Lift? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2005, 10:48 PM   #1 (permalink)
Official Saipan Member
rogerman's Avatar
View rogerman's Photo Gallery
Question Body Lift or Suspension Lift?
Hey guys im a noob when it comes to suspension so heres my question what is your opinion on lifts? Body or Suspension? anything welcome go ahead and skool me about this lol my uncle said bodys better but hes crazy so idk
1992 Hilux 4X4 22R-E Manual, LCE Headers, Epn cam, super 40, and revirginized.
rogerman is offline
Old 03-27-2005, 11:00 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Suspension is proper way to go. Who wants to see an ugly frame hanging down? And though a body lift lets you put on a bigger tire it doesn't allow any extra room for it to travel. Body lifts will also make you cut a larger hole in the floor for shifter clearance.
雄のハヤブサ
Tercel GTS is offline
Old 03-28-2005, 12:33 AM   #3 (permalink)
Young Buck
ElmerFudd's Avatar
View ElmerFudd's Photo Gallery
The big thing about lifting a truck is to have the travel in the suspension and have the clearance under the truck. Not to mention it improves the appearence of the truck. Body lifts are a cheap way out and will make the truck appear higher, but you as tercel says you see alot of the lines and cables floatin around when you expose the frame more. One other thing to keep in mind is that suspension will put a much more hefty dent in your wallet then a set of body mounts.
90' Toyota HTP Pickup 22RE 3" Body Lift Breathin K&N with 31" Sneakers.
ElmerFudd is offline
Old 03-28-2005, 12:34 AM   #4 (permalink)
View crazycruzer's Photo Gallery
I agree. Suspension lift is the proper way to go.
crazycruzer is offline
Old 03-28-2005, 01:27 AM   #5 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1000064
View humanoid's Photo Gallery
It depends what you plan to do with your truck, but I would go with a suspension lift. If you need more height then go with a body lift as well. Below is a link to the most common types of lifts and the pros and cons of each. Good luck...
http://www.CustomTacos.com/tech/inde...v2&id=137&c=10
This is my sig.
humanoid is offline
