99 4 runner check engine light problem
Hi there,
I have had an issue with my check engine light coming on. I have a 99 4 runner limited (6 cylinder) and my main mechanic has had troubles diagnosing it. I get what was called a "lean code" ( P0171 I think). the truck has CA emissions.
My mechanic (that I trust) replaced the air/fuel ratio sensor (PN 234-9002) which is the same as the oxygen sensor on non CA emissions trucks I guess.
My mechanic sent me to the Toyota dealer after a few tries at a fix (after the light came back on). The best that happened was that they (my trusted mechanic) had cleaned the Mass Airflow meter well and this kept the light out for a solid month before they gave up and sent me to the dealer when it came on again.
Now the dealer has told me I need both a new Mass Airflow sensor and an new air/fuel ratio sensor.
My question is...I thought I already replace the air/fuel ratio sensor? How many of them (O2 sensors I mean) are there and how can I know that the Mass Airflow actually need to be replaced?
Should I try cleaning the Mass airflow again? and lastly, if I do this, can I reset the check engine light myself to see if it is better? or will it just go out if the situation improves?
Is this Mass Airflow meter something I can replace myself? It looks very straight forward sitting there beside the air cleaner housing.
thanks!
Steve
