Clutch disengagement problem '92 truck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2005, 12:12 PM   #1 (permalink)
View HuskerSam's Photo Gallery
I own a '92 2WD 4 cylinder 22RE truck.
And it won't start or shift. Unless I get under it and manually help the slave disengage myself, while someone else depresses the clutch. But even if I start it that way, I still am not able to shift it. (I can only shift when the vehicle is turned off)
I've replaced the master & slave cylinders. While also bleeding the lines. Where can I go from there?
One mechanic I called said the synchronization could be bad. How do I check that?
Any feedback would be appreciated..
HuskerSam is offline
Old 04-01-2005, 02:55 PM   #2 (permalink)
View GregoryM's Photo Gallery
Husker: Sometimes the clutch pedal mount under the dash cracks and bends. Examine the whole assembly including the pivot area. I would also check the hydraulic lines and flex hose to be sure they are sound, then bleed the system again very carefully. Those can be difficult to get all the air out of them. It's frustrating but, you're on the right track. Keep after it.
Re. "synchronization", your mechanic may be refering to the synchro rings in the transmission which can only be changed by disassembling the transmission. I doubt if that is your problem though. Good luck.
GregoryM is offline
Old 04-01-2005, 05:30 PM   #3 (permalink)
itz a what thing?
View burger's Photo Gallery
can you see the clutch actuator moving in and out when pushing the clutch petal?the petal is also adjustable where it connects to the master cylinder plunger as well.will the truck start in neutral with the clutch cancel button on?
burger is offline
Old 04-03-2005, 06:44 PM   #4 (permalink)
Where is the clutch cancel located at? Thanks.
Old 04-03-2005, 09:37 PM   #5 (permalink)
King Dingaling
hillbilly's Avatar
View hillbilly's Photo Gallery
clutch cancel is that rectangle button just to the left of the steering collum, it says "clutch start cancel" just make sure you're not in gear when you start it.
turn your key on, push button, start.
87 4x4 22r 5spd
hillbilly is offline
