In a way, it's simple, but in another way, it's not.
In another thread, I mentioned that Toyota makes filters in multiple countries. That adds to the confusion, because equivalent filters made in different countries have different part numbers. You probably keep getting different numbers because your dealer is stocking whichever one is the cheapest at the time. (Filters made in Japan are the most expensive, filters made in Thailand are in the middle but close to the bottom, and filters made in the U.S. are usually the least expensive.)
I've talked to the parts guy at my local dealer, and he has told me that there are now just three basic filters - one each for 4 cylinders, 6 cylinders, and 8 cylinders. If the dealer is telling you it's right, I'd believe it. There isn't that much difference between the various Toyota filters anyway, so if it fits properly, it should be fine. (The V8 filter isn't a whole lot bigger than the 4 cyl. filter.)
