Fud, it shouldn't present a problem. Exactly what type of lift are we talking about? I've installed three 4" trailmaster kits on '89 and '90 trucks, and the offset has never presented a problem. I had 15X10 American racing alloys on mine. The reason it sometimes causes a problem is because there is a spacer that goes from the hub to the upper control arm, that in effect raises the arm. Ordinarily, the upper CM sitsdown near the wheel itself, but after the install, it is raised to where it could contact the rubber on the tire, if you have excessive negative offset.
BTW, 33's will fit fine with a 4" kit. Also, with these types if kits, the torsion bars aren't manipulated.
