I had this same problem of the temp guage never rising above 1/8. I changed the thermostat and it did not change temp guage position. I changed the coolant temp sensor and the temp guage returned to the normal 1/3 position at OT. Also noticed that an occassional idle speed miss disappeared. Evidently the sensor was telling the brain that the engine was cooler than OT and responded with increase in fuel or a timing adjustment or who knows what which was causing the idle speed miss. In my limited experience coolant temp sensors fail more often than thermostats. The parameters of a failure are much tighter for the sensor.
