temp guage never goes up much - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2005, 09:11 AM   #1 (permalink)
View fast68's Photo Gallery
ok in the 87 with 22re, the temp guage rarely goes up past about 1/8 way past cold... never.. thats high as it ever gets, even though engine seems plenty warm and heater too and all that
what is wrong ?
common issue?
thanks
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline
Old 04-06-2005, 10:24 AM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $231380
iTrader Score: 37 reviews
View Knailgun's Photo Gallery
I think it is a sending unit...mine did that once...there was buildup around it.
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline
Old 04-06-2005, 10:32 AM   #3 (permalink)
around what, the body of the sender, or for the wire plug ? where is temps ender on 22re in 87 ??
thanks
fast68 is offline
Old 04-07-2005, 08:55 AM   #4 (permalink)
ttt.......
fast68 is offline
Old 04-07-2005, 05:35 PM   #5 (permalink)
View karugs's Photo Gallery
Thermostat is stuck open. Get a new one.
karugs is offline
Old 04-07-2005, 06:14 PM   #6 (permalink)
View qsd-dan's Photo Gallery
Yeah, the cheapest route is to replace the thermostat and go from there. Make sure you get the 2 stage thermostat so you don't end up with "temperature guage overshoot"
qsd-dan is offline
Old 04-07-2005, 07:27 PM   #7 (permalink)
View Zetoe's Photo Gallery
TTT
I have this problem as well on my 1990 22RE 2WD pickup. i KNOW that the engine is hot, but I don't know how hot. Sounds like I need new t-stat?
Zetoe is offline
Old 04-07-2005, 08:40 PM   #8 (permalink)
Well, I actually thought it was the correct route (apart from it being the cheapest too). Many a time have I read threads on this topic.
karugs is offline
Old 04-08-2005, 04:44 PM   #9 (permalink)
it doesnt make sense that thermostat is stuck open when i have lots of heat and engine actually feels hotter than it should be, it gets so hot sometimes like today that it will cough/totally skip or miss every once in a while when sitting idling in gear, have to shut heater off it will cook you out of the cab,
and when its sitting and idling out of gear it will sound like popcorn in exhaust kinda but irregular
but it has good power and cruises and such all fine,
if therm was stuck open then symptoms would be long time to warm up, and/or would always be cold
but it heats up quick, sometimes too much, on some warm days
the guage is garbage i guess
just like the fuel sender, and and and...
thanks
fast68 is offline
Old 04-08-2005, 10:09 PM   #10 (permalink)
View Rycam's Photo Gallery
The factory Toyota gauge in the dash is an "idiot gauge" . I looks like a gauge but can act like an idiot light. How so? Toyota's temp gauges seems "weighted" to allow a range of temps to appear like a rock solid reading in the middle of the gauge.
After my dash gauge went dead, I installed a Sunpro electric temp gauge with the sensor in the factory location (in the top front of the intake manifold). This temp gauge has a needle that actually MOVES according to engine loads.
I actually like mechanical temp gauges better (wider gauge sweep, less electricals, reads even when the ingition is OFF), but the larger "bulb" sender bottoms out on the interior casting of the block...and is on the radiator side (cooler side) of the block. This area is also a low point in the block, as that is where the block drain is...and sediment can collect over the bulb.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 04-09-2005, 01:25 AM   #11 (permalink)
thanks
You're confusing me. Your first post mentioned the gauge didn't go above 1/8 of the temp gauge. Now you say it's hot.
But the temp gauge measures the COOLANT TEMPERATURE. Meaning, it's not circulating properly when it's stuck at 1/8 mark and you KNOW the engine is hot. So it does not absorb engine HEAT and it remains COOL.
By the way, it's easier to change the thermostat then the temp gauge...
karugs is offline
Old 04-09-2005, 05:32 PM   #12 (permalink)
i said the engine gets hot
not the guage
the thermostat is fine, everything gets real hot, radiator, hoses, engine, heater, all that stuff, its all normal,
just the guage never gets off 1/8 way past C mark
thanks
fast68 is offline
Old 04-09-2005, 06:50 PM   #13 (permalink)
Well, it's your car/truck. If you think the thermostat is fine, I have nothing else to say. Goodluck finding your problem.
karugs is offline
Old 04-26-2005, 07:01 PM   #14 (permalink)
View bob ventrillo's Photo Gallery
what is wrong ?
common issue?
thanks
I have a 94 4x4 that I bought new and the temp guage never has gone past 1/4. Noticed that it hardly moves now. Was ready to by a new sensor but will try the thermostat first. Thanks all for the advice.
bob ventrillo is offline
Old 04-26-2005, 07:08 PM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $874475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
more than likely it's your coolant temp. sending unit. if your hearing gurling noises from engine cooling system u might want to make sure all the air has been evacuated from the system.
The Jedi Speeder at CarDomain
MR2Jedi is online now
