'92 Toyota Truck---Won't shift while running
I've got a 5 speed 2WD pick-up 22RE
It won't start unless I get underneath and manually depress the slave cylinder, or push in the button (clutch bypass?) that sits in front of the clutch pedal. Once the truck is started then I can not shift at all. When it was going bad it got progressively harder to shift reverse being the worst..grinding, hard shifting etc.
So far I have replaced the slave and master cylinders, and the pressure plate, clutch and no change to the situation.
The actuating arm that goes directly into the transmission has about 3/8+ motion when working the clutch. The hydraulic lines have been blead and the pedal has pressure when depressed. The truck shifts fine when not running.
This one has really got me stumped, as well as any of my buddies that have come by to offer their two cents. Any thoughts would help and beleive me the simple solutions are the ones that are most likely being overlooked.
Thanks,
Sam
