Gasket question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2005, 03:28 PM   #1 (permalink)
JerryRigger
View woundedfate's Photo Gallery
Gasket question
I replaced a 22re and there is a coolent leak under the intake manifold. If I pulled the intake off to fix the leak would I have to get a new gasket or is the new one young enough that it hasn't binded yet and can be used again? (the engine has only been ran for about 20 min. total)
woundedfate is offline
Old 04-07-2005, 09:29 PM   #2 (permalink)
itz a what thing?
View burger's Photo Gallery
Where is the leak coming from under the intake? there are some coolant lines under there ,make sure you check to make sure the clamps are all tight before tearing things down.If you re-use the intake gasket i would use some sealer when you put it back together.
burger is offline
Old 04-07-2005, 10:13 PM   #3 (permalink)
JerryRigger
There is a pipe that goes straight up into the manifold. I can see water spraying out of it where a bolt got sheared off. I don't know if I can get a removal tool underneath it to drill out and remove the bolt.
