eep
how did you find the leak incidently, soap bubbles or a freon dye? if its a small leak i would shoot in some dye and let the car go through a heat/cool cycle whereby it sits overnight and everything cools and contracts. you may have more than 1 leak. besides if you gonna crack the system anyway you might as well fix all the leaks in one sitting. if its 134a just bleed off the freon, its enviro friendly.
as for things to consider... i would recommend a set of gauges in addition to the cantapper filling kit. if theres an obstruction in the system, especially between the high and low sides, bleeding one side wont release the pressure on the other. this can result in a face full of freon and a very nasty experience. wear some goggles. a recovery machine would be the safest and enviro friendly bet though
