Check on the side of the carb, there's a vacuum line that goes to a AAP valve, which is a diaphram that is vacuum operated on the side of the carb.. I bought a used toy once and found that was leaking causeing fuel to be pulled in with the vacuum. I also had a friend buy a used toy and he was wondering why his was running like that, and we went right for that diaphram and it cured the problem. I hope I have the intials right for the name of that valve. Its been so long since I had a carbed toy. I forget what I use to know. nyway, if you buy a toy part number its 40 bucks plus. Good Luck
