stumped-fuel system related? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2005, 02:41 PM   #1 (permalink)
View deadelvis's Photo Gallery
I recently found out i had a head gasket leak on a 91' 22 re 4x4. The truck was running alright even with the problem other than that it was putting coolant into my oil. I replaced all the gaskets, put everything back together according to specs, and it won't run for more than 5 seconds without shutting off. if you spray gas into the throttle body it will continue to run, but other than that i've had absolutely no luck with anything else. would really appreciate it if anybody has any suggestions. I think it something pretty minor, but really have no clue what part of the fuel system and or electrical system to check.
deadelvis is offline
Old 04-13-2005, 03:07 PM   #2 (permalink)
View YumaBill's Photo Gallery
have you checked your connections (electical) on the injectors?is the fule pump working (fuse)?
I would start there
YumaBill is offline
Old 04-13-2005, 03:11 PM   #3 (permalink)
i know for sure all the electrical connections on the injectors are working fine, i checked the fuses, but i'll double check them.
Old 04-13-2005, 06:31 PM   #4 (permalink)
okay, it's not the fuses, not the fuel pressure-it has that, not the injectors, for some reason it's not getting enough fuel to run for longer than 3 seconds. any other help would be much appreciated.
Old 04-13-2005, 06:35 PM   #5 (permalink)
Peter's Avatar
View Peter's Photo Gallery
dis conncect the battary for 15 min and re connected...it could be that the computer had a glitch....doing this u will rest ur computer in ur truck and should give u a proper fuel mixtur.....and that dosnt work look at the injectors...are they dirty or any thing????
Peter is offline
Old 04-13-2005, 06:59 PM   #6 (permalink)
itz a what thing?
View burger's Photo Gallery
How do you spray gas in the throttle body if the MAF is hooked up?if you did have the MAF hooked up,check your grounds-if you didn't,your truck won't run without it.
burger is offline
Old 04-13-2005, 07:08 PM   #7 (permalink)
ok i just unplugged battery, as for the mass airflow it is hooked up along with the grounds if im not mistaken. but yes if i continue to spray gas in the throttle body it willl remain running. this is what is confusing me because it would point to a fuel pressure problem but i have at least 45psi fuel pressure
Old 04-13-2005, 08:17 PM   #8 (permalink)
View Smoke's Photo Gallery
You have to have the air tubes hooked up between the MAF and the Throttle body with no leaks. If the hoses are unhooked or leaking between the two it will do just as your saying!!
94 Toyota PK Ex-Cab 3.0 4X4 Auto
Smoke is offline
Old 04-13-2005, 09:01 PM   #9 (permalink)
thanks a lot smoke runs great now i owe you a case of beer
