83 4x4 Engine swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2005, 09:04 AM   #1 (permalink)
Newbe
View Maxx's Photo Gallery
83 4x4 Engine swap
Just got a 83 4x4 with a junk motor. Crank walked almost .25 inch forward so the block is junk, but the head was just rebuilt. I would like to replace it with the same engine to save hassles with emissions and wiring.The trouble is I can’t find a 83 or 84 engine or block to use. From what I have been able to find out those are the only two years that are a direct bolt in. If this is wrong please enlighten me. Or is there another year that is close so there won’t be to many modifications. I have line on a 82 but then I can’t use the rebuilt head because of timing chain issues.
Thank Kevin
Maxx is offline
Old 04-17-2005, 11:34 AM   #2 (permalink)
Trailer Trash Engineer
alltrac165's Avatar
View alltrac165's Photo Gallery
I could be wrong, but I thought they were all the same until 86 when they changed the deck height and used a different head.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
alltrac165 is offline
Old 04-17-2005, 01:16 PM   #3 (permalink)
Newbe
Yes you are correct, they will all bolt in but the wiring and emissions don't match. I’m not much on wiring. After 82 they went from a double roller timing chain to a single roller set up. So I am assuming I can’t put a 83 head on a 82 block?I don’t know to much about Toyotas, this is my first one. But I have owned three (cough JEEPS ).
Kevin
Maxx is offline
Old 04-18-2005, 04:26 PM   #4 (permalink)
View wight tale deer's Photo Gallery
i have an 83 toyota 4 cyl that still runs and everything.. it dont burn oil.... but i live in alberta, canada.... r u in th area
wight tale deer is offline
Old 04-20-2005, 03:14 PM   #5 (permalink)
Newbe
Nope, just a little south of you, Grand Rapids, Michigan.
Thanks though
Kevin
Maxx is offline
Old 04-20-2005, 03:42 PM   #6 (permalink)
View Billy_The_kid29's Photo Gallery
I have heard of ppl putting 20r heads on a 22r block.posed to be kick ass
ottawa canada
Billy_The_kid29 is offline
Old 04-20-2005, 03:52 PM   #7 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
You can put any 22R block in your truck, just not a 22RE. 22R's from '81 to '84 will work, even one out of a pre-'85 non-EFI Celica, although you will have to change the oil pan and oil pick-up tube.
DCM is offline
Old 04-20-2005, 04:20 PM   #8 (permalink)
what about My engine?? I have an 86 pick up with a 22r
ottawa canada
Old 04-20-2005, 04:38 PM   #9 (permalink)
Newbe
I know 22R's from '81 to '84 will work, but the emmissions and elec. stuff arn't the same, or is that not to much of a hassel to deal with?
I would like to use the head I have, its just been rebuilt.
Thanks Kevin
Maxx is offline
Old 04-20-2005, 07:37 PM   #10 (permalink)
alltrac165's Avatar
Shouldn't be a hassle. Just keep the emissions and electrical stuff from your truck. Heck we just put an 86 engine into an 84. Used all the 84 intake stuff, exhaust, and electrical. Those are different engines. The 86 has the pear shaped exhaust ports and the 84 had the round ones. Different deck height, etc. Intake is the same, though. All the outside stuff bolted right up. The only problem I can imagine you having is the timing chain in the years you are mentioning. Make sure you have a new kit, and just use that. Then you have the same rows top and bottom. I don't think the distance from crank to cam changed, did it?
Bob Raby
Santa Cruz, CA
Old 04-21-2005, 12:38 AM   #11 (permalink)
slacker's Avatar
View slacker's Photo Gallery
any 22r from 81-84 will be a direct bolt in ... heads are the same ..
theres some info here .. http://www.members.shaw.ca/slacker502/technical.htm
double chain is quite a popular swap in to these engines ... I have done it many times , and would highly recomend it . all you need is the longer oil pump drive gear to swap in to make it happen .
slacker is offline
Old 04-21-2005, 05:46 PM   #12 (permalink)
Newbe
I have a line on a 82, but the rebuilt head I have is to an 83. So all I should have to do is get a double roller gear for the head right? Thanks Kevin
Maxx is offline
Old 04-21-2005, 06:02 PM   #13 (permalink)
slacker's Avatar
No ... you'll have to get the whole double chain set , including gears , guides , chain and tensioner ... then you'll have to get the oil pump drive gear for the double set up .
slacker is offline
