Gears - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2005, 05:34 PM   #1 (permalink)
TOYO-MAN
View sonofmayhem's Photo Gallery
Gears
i wanna get new gears for my 85 4x4 sr5 22re efi 30in and 33 in and in between tires. any suggestions
sonofmayhem is offline
Old 04-18-2005, 06:54 PM   #2 (permalink)
View black93DX's Photo Gallery
4.10's should be fine all the way up to 33's. Go 4.56 or 4.88 after that.
93 DX Ext. Cab.- 5 speed,FM40,K&N,31x11.50 RVT's
black93DX is offline
Old 04-18-2005, 10:33 PM   #3 (permalink)
TOYO-MAN
thanks does anyone know where i can get 4.10s for my 85 4x4 std cab 5spd and ?should i put them in front too?
Old 04-18-2005, 11:30 PM   #4 (permalink)
Young Buck
ElmerFudd's Avatar
View ElmerFudd's Photo Gallery
Don't they come 4.10? Correct me if I'm wrong.
90' Toyota HTP Pickup 22RE 3" Body Lift Breathin K&N with 31" Sneakers.
ElmerFudd is offline
Old 04-19-2005, 06:08 AM   #5 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Listen to ElmerFudd and look for some 4.88's if going to 33".
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 04-19-2005, 11:08 PM   #6 (permalink)
snowboarder2359's Avatar
View snowboarder2359's Photo Gallery
4:88's
Brandon
~ 1992 Toyota Pickup 4x4 DLX 22-RE ~ 121,000 miles ~ Flowmaster 40 Series ~ 3" Lift ~ 33x12.5 On The Way ~
snowboarder2359 is offline
Old 04-20-2005, 06:30 PM   #7 (permalink)
TOYO-MAN
thanks guys with out all this help id be broke! so are gears easy to do yourself, do you need a lift or can i do it w/ some jack stands?
Old 04-20-2005, 06:54 PM   #8 (permalink)
texas12's Avatar
Not a DIY project for most people. There is very critical run-out specs when installing the gears.
texas12 is offline
Old 04-30-2005, 12:19 PM   #9 (permalink)
TOYO-MAN
could i throw in some 4.88s or 4.56s, and keep the 30s and expect trouble?
85, lifted and ready to rock!
Old 04-30-2005, 12:43 PM   #10 (permalink)
View Toy Sport 4x4's Photo Gallery
The manual trucks come with 4.10 or 4.11 same difference most auto come with 4.30. Both axles must match or the tires will spin at different speeds and lead to damage. I would go with 4.56 if you are planning on running different sizes of tires. If you are only going to run 33 go with 4.88. Running that ratio with smaller tires is going to put highway rpms very high.
Toy Sport 4x4 is offline
Old 04-30-2005, 03:14 PM   #11 (permalink)
View Rycam's Photo Gallery
I must insist that 4.10 gearing is ONLY good for up to LT235/15 tires!!!!! That is roughly 28" tall. 30x9.5 is bearable to an extent. 32" is f'ng MISERABLE!!!!
The government has been all over manufacturers for decades. If TOYOTA took the logic of "up to 33" is OK", they would have installed 3.90's or "worse" right from the factory to increase MPG. The 1980 4x4 models run 3.90...this only lasted one year if memory serves...for good reson: it sucked!
Gears and tires are hand in glove. They must match.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
