Unable to remove key!
Key won't turn to off position, Finnally after removing battery so truck wouldn't go dead it goes into off position. So I figure it's not telling ignition switch it's in park. I went throug the fuse panel & started pulling fuses one at a time.With the accesory fuse removed, the key works fine. But without the fuse no Radio & some idiot lights come on. What I need to know now is there a switch somewhere in shifter that tells ignition that it's in park? Where is it located? pat name or number? Or anything that might help. Yes I tried other keys! Thanks for any help.
