locker question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2005, 09:24 PM   #1 (permalink)
View bikerider's Photo Gallery
2nd Generation locker question
was looking for some lockers for my 90 4runner was wondering what you guys thought might be best ive looked and some air lockers and another kind but for got what they where and one that really caught my eye where some called ox lockers i think a little on the high end but they sounded good on paper anyhow let me know what ya think thanks alot
bikerider is offline
Old 04-21-2005, 10:32 PM   #2 (permalink)
View Rycam's Photo Gallery
The OX locker sounds great. Unfotrunately, I only know of Dana applications. The rear cover of the Dana (D44 or D60) is removed and a heavy cover with the shifting mechanism is installed.
Toyota rear diffs, and the strong Ford 9'' diffs are not constructed with a removeable rear cover. They seperate from front of the axle housing with an integral third member/ring/pinion assembly.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 04-22-2005, 03:14 PM   #3 (permalink)
View black93DX's Photo Gallery
ARB air lockers are good, as are Detroits.
93 DX Ext. Cab.- 5 speed,FM40,K&N,31x11.50 RVT's
black93DX is offline
Old 04-22-2005, 08:13 PM   #4 (permalink)
thanks for the replies guys i think im going to try the detroits but im getn the lift next week so ill see how much of a difference that will make im sure it will be a bunch considering ive always been stock height it will be like driven a whole new runner have a good and thanks again
Old 04-27-2005, 05:38 PM   #5 (permalink)
View Toy Sport 4x4's Photo Gallery
I have a detroit in the rear of my 88 pickup and it works great. You can really tell it when power is added or removed because it makes the truck shift a little. If you don't ease off the gas in curves it will also make the front tires wear on the outside because it will still be trying to push you straight. They are supposed to unlock to allow for cornering but are hard to get to unlock
Toy Sport 4x4 is offline
Old 04-28-2005, 05:45 PM   #6 (permalink)
so would you recomend that i just get them in the back are on all four. thanks for the replies
Old 05-02-2005, 08:15 PM   #7 (permalink)
View detcord's Photo Gallery
USA
Why would you need 4?
One locker up front and one locker out back...the locker locks the differential so that both tires turn equally.
detcord is offline
Old 05-02-2005, 09:47 PM   #8 (permalink)
sounds good but im new to the lockers and thats the first ive heard of running one up front and one in the rear thanks for the info ill look into that
Old 05-10-2005, 11:14 AM   #9 (permalink)
I personally would not put a detroit in a front axle of a daily driven vehicle. Most lockers either replace the carrier to lock the axles together and some just replace the side and spider gears and use a clutch like system to lock the axles. If money isn't a consern I would put a detroit locker in the rear and a detroit true trac in the front. ARB lockers are said to be good but i have heard of the o-ring in the dif. where the air line comes in tends to mess up.
Old 05-10-2005, 08:18 PM   #10 (permalink)
thanks for the reply i think for now ill go with the detroit in the rear cause in still thinking about the solid axle swap thanks again
Old 05-11-2005, 10:51 AM   #11 (permalink)
Darren's Avatar
View Darren's Photo Gallery
If you're not familiar with lockers, you're definitely NOT a candidate for a solid axle.
2002 4Runner Sport
285/75/16 MT/R's | Sway-A-Way & Old Man Emu suspension lift | TJM T15 front bumper | Rock Ware rear bumper | Slee sliders | Dual ARB's | 4.88 gears | Mickey Thompson Classic II's
Darren is offline
Old 05-11-2005, 11:57 AM   #12 (permalink)
robinhood150's Avatar
View robinhood150's Photo Gallery
Exactly.
'93 4Runner V6 Auto 4x4
Robinhood's Lair.
robinhood150 is offline
Old 05-11-2005, 08:59 PM   #13 (permalink)
so outa all the years ive had a 4runner and used and abused the ifs your sayn that i shouldnt get a solid axle so what i should never learn how to drive with anything other than an ifs thats poop im asking these questions cause im tring to improve on what ive got and know about offroading but thanks for the help
Old 05-11-2005, 11:35 PM   #14 (permalink)
How many CV axles have you broken? Are you still able to get an alignment or is your suspension so bent than they can't do it anymore? How many idler arms have you destroyed?
What darren and I are trying to tell you is you don't even have 1 locker yet, let alone 2, so you don't know the limits of your truck. You may think you do, but based on your past questions, I don't think you do.
Do you care if you flop your truck on its side or rolling it? Do you care about mashing your doors into some boulders? Can you weld well enough to trust your life on it? With IFS, some armor, and some lockers, you can run the rubicon. Are you going to be doing trails as hard as or harder than the rubicon?
When you're ready for an SAS, you'll know it. You won't have to ask.
In the mean time, you can search around on www.pirate4x4.com for sas questions. I warn you, do NOT post any questions. SEARCH first, or you will be flamed so bad you'll be turned off of 4wheeling forever. Be sure to look through the FAQ in the toyota section.
I'm trying to guide you, but you have to do the leg work. Don't expect to learn everything in a couple days, it would take even me months to do the proper research to do a SAS and I already have an idea of what's involved.
Robinhood's Lair.
Old 05-11-2005, 11:40 PM   #15 (permalink)
Young Buck
ElmerFudd's Avatar
View ElmerFudd's Photo Gallery
Give the guy a break, obviously he knows there are advantages to a solid axle, doesn't take a genius to know the difference. Besides, what does locker locker knowledge have to do with the 150% more flex and dependability of a solid axle offroad?
90' Toyota HTP Pickup 22RE 3" Body Lift Breathin K&N with 31" Sneakers.
ElmerFudd is offline
