2 questions. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2005, 11:11 PM   #1 (permalink)
orange brick
80toy's Avatar
View 80toy's Photo Gallery
Question 2 questions.
1980 4x4 pickup, 20r (2189cc), 4spd manual, 110,000 original miles
Question one-- I have an exhaust leak that will not go away. it is where the exhaust manifold meets the block. i have had the manifold and block resurfaced and some other work done with the studs, but i cannot get rid of this problem. any advice? i am a student on a budget.
Question two-- My truck lacks power and a 5th gear. I am wondering if the stock 20r will have enough in it to push a 5th gear? If not, what simple power adders do you suggest? I was thinking a Weber 32/36 and a header, but is there a smog legal header? Also, where could i find a cheap but reliable 5spd?
Thank you.
80toy is offline
Old 04-23-2005, 12:37 AM   #2 (permalink)
Young Buck
ElmerFudd's Avatar
View ElmerFudd's Photo Gallery
Do you have a gasket between the block and header? And my guess is if you're having a problem with power with the 4 speed tranny, the 5th gear isn't going to make it any faster, my bone stock 22re has enough trouble with 5th.
90' Toyota HTP Pickup 22RE 3" Body Lift Breathin K&N with 31" Sneakers.
ElmerFudd is offline
Old 04-23-2005, 03:04 PM   #3 (permalink)
orange brick
80toy's Avatar
2 question clairification
Sorry, forgot to say that i just want the 5th gear to run at a lower RPM on the freeway. right now i am pushing around 3000 RPM somewhere inbetween 55 and 60 MPH, and i don't reallt like it. so i think a 5th gear would be nice.
as far as the gasket, i did not do it myself, i had it done when i first got the truck. they put in longer studs, and resurfaced the block. it worked for a while, but the exhaus leak eventually came back. i have heard that the exhaust manifold on these trucks can be problematic. i am wondering if anyone has had similar problems. thanks
80toy is offline
Old 04-23-2005, 03:31 PM   #4 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Yep, had that problem with my 22re. Kept leaking all the way at the back of the manifold (rear of head). After a couple tries and several gaskets, finally got it to seal using gasket sealant with the gasket. Be careful not to strip a stud in the head, did that too. Not fun .
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 04-24-2005, 12:57 AM   #5 (permalink)
Young Buck
ElmerFudd's Avatar
Yeah I'd say take the header off and use some sort of heat retardant gasket seal. I have a small leak coming from somewhere up front but it's not really buggin me too much... might take some time to look at it when I have lots.
