Originally Posted by sloppychicken
Okay, I don't think its the throw out bearing rubbing on the pressure plate. I had my brother start the truck and I went underneath and pushed the fork so that it pulled the throw out bearing away from the pressure plate and the noise didn't change. When you put a little pressure on the clutch pedal the noise goes away. It sounds like it is coming from the front of the truck. Would that make sense? I used the screwdriver on the ear trick and couldn't locate it. The sound is severe like a lathe would sound. Could there be a problem form a poor rebuild on the motor? Why would it change when the clutch was pushed in?
Okay, so you determined that its not the throwout bearing itself that is making the noise. I have no idea what could be making the noise if it is coming from the front of the engine, since the clutch is not even part of the engine...its just controlling the slave cylinder.
Could it be the tranny? Since the input shaft for the tranny is turning while it is in neutral (clutch pedel not down)....and then you push the pedel in, this stops the tranny, eliminating the noise???? But then you said if you put a little pressure on the pedal. How little? Enough pressure to disengage the clutch and put it in gear?
I dont know...thats my best guess. I don't think it would involve anything with the clutch (clutch, pressure plate, pilot bearing, throwout bearing) since you eliminated the possibility of the throwout bearing.
Let us know what you come up with...
