[QUOTE=molcanic44]89 toyota pick up(22re manual) is stalling on me on start up.idle for 3-5 seconds then stalls.have checked for air leaks and found no prob.[/QUOTE ]
Have you jumped the diagnostic connector and checked for codes? Does it stall when the motor is hot or cold? Can you get it to run for longer periods of time if you throttle it? These symptoms sound like the possibility of the following parts malfunctioning: fuel pump, fuel pump relay, computer, ignitor, coil, AFM (air flow meter), distributor, cold start injector and cold start injector time switch (if stalling when cold), EFI relay, circut opening relay, EGR stuck open and probably some others that I can't think of at this time. These can be narrowed down with more detailed info of your problem. Let us know
