ECU resetting? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2005, 08:30 PM   #1 (permalink)
View toysports2k's Photo Gallery
ECU resetting?
Can you really "reset" the ECU for the 22RE? The guy at Cal Mini Trucks says "yes" and makes it seem like after any performance upgrades you need to do this. Won't tell me how it's done (i don't blame him, it's how he makes his money, i guess). Anybody out there that can confirm or deny. And if it IS true, how?
toysports2k is offline
Old 05-01-2005, 11:34 PM   #2 (permalink)
View sefus's Photo Gallery
if i remember right just take the negative terminal off your battery for 20minutes. that should do it.
86 Toyota 4runner, 22re, 5spd: .02 over, head shaved for 9.5:1, full port and polish, 48/40 valves, dual valve springs, cam, header & exhaust, Supra AFM, SHO Taurus electric fan, removed AC, MSD 6a and coil, and a bunch of other little stuff
sefus is offline
Old 05-02-2005, 07:44 AM   #3 (permalink)
Gameroom cash: $249045
View toto's Photo Gallery
There might also be a fuse for the ECU in the fuse box that you can remove to cut the power and then replace it.
2009 Tacoma DC SB TRD Sport 4x4
Retired: 2000 Tacoma Xtra Cab V6 TRD Off Road 4x4
toto is offline
Old 05-03-2005, 01:51 PM   #4 (permalink)
Thanks! I'm thinking i end up resetting that ECU every couple of weeks when i unhook the ground to work on the body or electrical. I originally was thinking that resetting the ECU might correct my engine running rich.........now it must be something else.
Old 05-03-2005, 06:59 PM   #5 (permalink)
tcr22's Avatar
View tcr22's Photo Gallery
you can fix your rich problem with the mass air flow meter trick
tcr22 is offline
Old 05-04-2005, 02:06 PM   #6 (permalink)
i'll try the MAF trick...... i had the guys at Cal Mini Truck do some "tricks" a while back and i believe they bumped up the MAF a little. it ran fine and the a/f mixture was coming in fine. now all of a sudden it's running rich. i haven't done anything to it recently except add a hyper-ground system. i can't believe that by adding a thicker grounding wire system would cause the motor to run rich. i've tuned the motor (new plugs, cap, rotor, adjusted valves) and it's still running rich! maybe clogged vacuum lines?
