94-22re runs rough at driving speeds
Hi all,
New here.
I have a 1994 22re pickup that is having the stutters at the higher rpms.
I have replaced the following:
Air cleaner
Spark plugs
Spark plug wires
ECU modulator
O2 sensor after the catalytic converter, did get a check engine with this one.
Not much left to change.
No check engine light shows now.
I did some vacuum checks, while the engine is running at high rpms and stuttering i can pull
the vacuum line to the EGR valve and everything smooths out.
I'm about to change some or all orf the vacuum lines, but they all seem to be OK.
I did the idle speed check on the EGR valve with vacuum and the engine dies like it say in the Haynes manual. I ohm sifted the three vacuum switches on top of the engine, they all
read the same, about 35 ohms.
I've run out of ideas. Any suggestons?
ger
