Idle Surging - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2005, 11:51 AM   #1 (permalink)
View missy68k's Photo Gallery
Idle Surging
I have a 90 4Runner SR5 with a 3VZ-E (V6 3.0 EFI). At running temp. the idle will surge when brakes are applied or the clutch is in, from 900 rpm to about 1500 rpm. Any ideas where to start would be great.
Thanks
missy68k is offline
Old 05-04-2005, 12:02 PM   #2 (permalink)
View chilli's Photo Gallery
I had the exact same thing, and it was a dead EGR valve.......when its idling like shyte, open the hood, and push down on the EGR.....if the idles settles down, your EGR is shot!
chilli is offline
Old 05-04-2005, 12:02 PM   #3 (permalink)
PS - mine is a 1990 v6 sr5 too
chilli is offline
Old 05-04-2005, 12:19 PM   #4 (permalink)
Thanks, I'll try it & let you know if that was the problem. I hope it's that easy, I've only had one vehicle I liked better, and that was a 91 MR2.
missy68k is offline
Old 05-04-2005, 07:31 PM   #5 (permalink)
nofear4189's Avatar
View nofear4189's Photo Gallery
my truck does the same thing. Where exactly is the EGR vlave,and what do i have to do to check it. Like you said to hold down on it or something.
-Adam-
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
nofear4189 is offline
Old 05-05-2005, 06:32 AM   #6 (permalink)
View tr918's Photo Gallery
Also check the PCV valve.
tr918 is offline
Old 05-05-2005, 12:53 PM   #7 (permalink)
yup..I started by checking all vacuum lines, then moved to EGR (then would have moved to PCV)
The EGR valve (on my 1990 v6) is near the power steering reservior....if you are looking into the engine compartment, it is on the left of the engine, and it looks like an upside-down UFO (sorry for the lame description) You should see a small vacuum line running to it, and if you follow the pipe down, it enters the exhaust manifold. The valve is about the size of a baseball, and looks like an upside down saucer
If someone will host the picture for me, i have an example of the EGR valve
chilli is offline
Old 05-05-2005, 01:46 PM   #8 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
not on the topic....but chilli...i can host for you
www.djmodifyd.com
go there to sign up
alex is offline
Old 05-05-2005, 02:53 PM   #9 (permalink)
ok, signed up...will host as soon as I can
chilli is offline
Old 05-05-2005, 03:35 PM   #10 (permalink)
View Toy Sport 4x4's Photo Gallery
Also check throttle position sensor. It might be out of adjustment. If it not set on idle when the vehicle is at idle it will mess up fuel mixture.
Toy Sport 4x4 is offline
Old 05-06-2005, 08:42 AM   #11 (permalink)
Daym
I cannot login to the FTP from work.
I can email someone the pictures....gimmie an addy
chilli is offline
Old 05-06-2005, 11:38 AM   #12 (permalink)
missy68k@yahoo.com. Thanks again.
missy68k is offline
Old 05-06-2005, 12:12 PM   #13 (permalink)
pics emailed to missy
chilli is offline
Old 05-06-2005, 02:32 PM   #14 (permalink)
DJModifyd
alex's Avatar
here are chillis pics:
alex is offline
Old 05-10-2005, 03:07 PM   #15 (permalink)
btw - my low end power increased significantly....I wonder how long my EGR was "going" before it finally hung a dump!!??!!??
Be sitting down when you price a new egr valve though.....they wanted 300+ here at my local toyota dealer (thats canadian though)
I found a used on with only 60,000 miles on it, and my original lasted 331,000 KMS, so i figured....what the hell!
chilli is offline
