Got up to go to school this morning and got nothing but the click of the starter relay when I went to start. So, after I got home, I investigated this.
I knew it wasn't the clutch cancel circuit, because you could hear that relay...same with the starter relay. I was thinking it might have been the starter.
I had a friend turn the key over several times while I listened under the hood. I could hear the starter relay, but I could also hear a wire shorting out. I remember reading a post talking about the wires shorting out that run under the intake manifold:
http://www.toyotanation.com/forum/t14957.html
I found it! I will also post this as a new post for I think others may have the same problem. The wiring harness that runs under the intake between intake and injection assembly rests on the assembly. Apparently over time the vibration wore through the wrapping and insulation exposing wire. The harness was arcing to the assembly thus creating a short to the ignition. It had actually pitted the metal over time yet was hidden by the harness. I wrapped it and problem was solved. This is probably a common occurence for this is the factory routing for this harness.
I could definitly hear the short coming from the intake. I wiggled the wires around that ran under the manifold, looking and feeling for anything that was rubbing. Its a tight space so I couldn't really see anything.
A while after messing around, I tried to start it.......and it started.
Okay, so i guess wiggling around those wires fixed it???
I wanted to see if that was the problem, so while the truck was running, I wiggled the same wires around hoping to get one to short out like it did. No luck.
So I don't know what is wrong, but I want to get it fixed so it doesn't do this again. Has anyone had this problem? Can anyone explain where exactly it is rubbing? I was thinking I should just take my manifold off and see what is going on....and while I am at it take my injectors in for cleaning/testing.
I have a feeling that if there are wires shorting out, then this is what is causing my engine to cut in and out when I go around a corner (not all the time....but it only happens when I turn right):
http://www.toyotanation.com/forum/t65750.html
Any ideas??? Sorry for the long post
