it would seem that you have to block the return to make more pressior in the fuel rail . could pull the injectors and have them tested to make sure they are working right . what ever you do don`t use after market injecters go to jusk yard and pull toy injecters befor doing this . if this is a no go sure i have a set in the shop from a 86 that should be the same hookup as the 85 know the 88 hook is different but easy fix with wire change out
reason for not using after market injecters is they will work but nippel is a little shorter then stock injecter and this will stop the injecter from spraying mist into motor as it should I have had to replace more the one after market injecter for this every reason . you would be looking at around 400 for new is why i was saying to look at getting them from junk yard.
if you can not find them drop me a line at
Marty_redman2001@yahoo.com under injecters need and we will see what we can do .
