Having Major Problems! Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2005, 03:23 PM   #1 (permalink)
View cmfireman's Photo Gallery
Exclamation Having Major Problems! Help
I have a 1987 Toyota Pickup with 22R engine. The alternator quit charging one day and I replaced it with a new one. It still wouldn't hold charge so I took it to Autozone to have it tested. It was a good alt. Ever since this, the truck will turn over but isn't getting any fire to the coil. I know a little about mechanics and have checked the obvious wiring, relays and fuses but still no clue. Any help would be greatly appreciated. Thanx
cmfireman is offline
Old 05-14-2005, 12:17 AM   #2 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Gotta check the basics.
Do you have a spark on the plugs? Pull a plug, reconnect it to the wire and see.
Do you have gas? Carb'd should be easy to check.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 05-14-2005, 03:48 PM   #3 (permalink)
82toyo's Avatar
View 82toyo's Photo Gallery
I had the same problem and turned out that my coil was bad.
82toyo is offline
Old 05-16-2005, 09:51 PM   #4 (permalink)
View truck action's Photo Gallery
A bad alternator can take out the battery. Make sure yours is good. Also check the ingitor.
truck action is offline
Old 05-17-2005, 06:17 PM   #5 (permalink)
The coils aren't firing at all, because their is no power to them. I can't find any information on what would cause the coils not to fire at all. We also changed the coils and ignitor, but got no results. Appreciate all the help.
Old 05-17-2005, 11:29 PM   #6 (permalink)
82toyo's Avatar
You might want to check the voltage regulator.
82toyo is offline
Old 05-18-2005, 10:22 PM   #7 (permalink)
Thanks 82Toyo, I haven't thought of that, I'll check it 2morrow and get back 2 you on the results
Old 05-18-2005, 10:26 PM   #8 (permalink)
Hey, I asked a mechanic about the voltage regulator and he said that on most new or remanufactured alternators, the Voltage regulator is built in with the alternator, so if my alt. tested good, this shouldn't be the problem. Thanx agian for all the help, maybe we'll find the problem soon if I keep getting new Ideas from ya'll. I havent even got to take my new-old 'yota muddin yet!!
Old 05-20-2005, 01:37 AM   #9 (permalink)
82toyo's Avatar
sorry about that-my 82 has a seperate voltage regulator mounted by the coil, forgot that newer trucks have them built into the alt. Good luck, mine was doing the same thing but my ignitor went bad, replaced it and it started right up.
82toyo is offline
