Radiator nasty coolant problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2005, 06:48 PM   #1 (permalink)
WillBHomesoon
View WillBHomesoon's Photo Gallery
I have a 97 ext cab Tacoma 4x4 V6 3.4 It just turned 100k and for about a year now, ive been flushing out the radiator since i noticed really nasty looking brown dirty coolant. I dont know if a previous garage that worked on it put recycled brown coolant in it? Anyway, ive used prestone radiator flush twice in the last year and than good coolant, and it still comes back brownish at each oil change. Anyone familiar with this problem? Heater core maybe going bad?Thanks for your replies!
WillBHomesoon is offline
Old 05-16-2005, 06:57 PM   #2 (permalink)
itz a what thing?
View burger's Photo Gallery
Rad fluid is very corrosive if not changed regularly,and it may have damaged the heater core,but more likely it's eating away at the head gasket .The brown stuff is rust,and you'll probably have to put a gasket in in the next 10K.try putting stop leak thru the system to seal things up,it will buy you some time.
'90 4Runner R.I.P. '95 Tacoma XcabSR5. '89 4runner (burned up)'97 4RunnerSR5
burger is offline
Old 05-16-2005, 10:30 PM   #3 (permalink)
View Rycam's Photo Gallery
Antifreeze needs to be mixed with distilled water. Tap water contains minerals and can mess with the pH of the solution.
Make sure your ground straps from the head/block/body are connected. If you cant locate them...add a couple of your own. They are only a few dollars each, or free at the pick-n-pull.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
